Hei.
I have created a cam / milling part that requiers sever works setup - G54-55-56-57 as it needs to be indexed while milling.
Are there a way to sort the operation after tools - meaning i want to complete all the opereations with the active tool, milling features from several setups. I tried to use the folder functions and collect the same tools there, but the folder always get stored under one of the setups, and when dragging one operation into the folder, it changes the setup to the setup belonging to the folder, so i need recalculate the toolpath and then it gets a wrong G54-55-56.
It seems like i managed to get it work once, but now i can manage it anymore.
I'm not sure what you mean exactly.
Are you trying to create a single program in which you manually index the part, as in a vise or several different vises?
Edit: or are you indexing on a rotary?
Hello again. Not easy to explain by words. mby i need to post you a file?
Im using an indexer - A axsis paralell with the x-axsis.
I prefer to use one setup for each side on the tombstone - part that are machined to get better tolarances.
It means that in the program I would need to make several setup - one for each indexed site.
When using the same tool in many setups I would like to be able to sort the operations after tools - and in a specific order, picked from the different setups.
Taking T1 from setup 1-2-3 then T3 from setup 3-2-1, T10 from setup -2-3-1
If i put all the same tools/operations in one folder the operations changes the setup to the same setup as where the folder are stored under. So it can be used as the setup(G54.... ) will be wrong
Did it become more clear?
If not let me know what kind of file/illustration you need to be able to help.
Thanks in advance.
Hmm - not good.
Will it help you if i send you a programmed file - mby it will make you understand the problems better?
Thats surely a thing to improve in the SW if it cant be a possibility to complete the opererations from one tool taken from different setusp - thats a big need when will parts on a rotary.
When iI see how good this SW works in other fields - it surprise me that this cant be done.
What kind of file format could help you?
Thanks for feedback.
Sometimes its hard to creat a correct rotation line or setup of the parts in the machine and it can be easier to have severla worksetups in the mill - easier to adjust the part to.
Like in this part we premake the wood part in an old machine and do part of the milling in CNC. and we dont have a correct 3D model of the part.
By using a new work setup on each side I can adjust it easy to fit not needing to think of the center of rotation.
But would like to complete all the work with one tool on all sides before chaning tool.
I attach the machining order window from my current cam program.
Can something like this be done in Fusion.
