here are few methods to convert EML files to PDF, you can use:
Online tools:
Zamzar or CloudConvert for quick, simple conversions.
Email Clients:
Outlook or Thunderbird: Open EML and print to PDF.
Software:
SysTools EML to PDF Converter for batch conversion and custom settings.
Command Line (Advanced):
Use Python or Linux tools for bulk conversions.
Each method suits different needs, depending on scale and frequency.
Yes! you can convert your EML files to PDF by using Advik EML to PDF Converter program. I've converted over 5000 EML files with just a few clicks. This utility offers two options: single file or a file in bulk. I chose the multi-file option to upload all my EML files and converted them all to PDF files with just two or three clicks of "Next," without any corruption. If you're reading this discussion, you can try it too.
You can convert EML files to PDF pretty easily. If you open the EML in an email client like Outlook or Thunderbird, you can just use Print → Save as PDF.
If you don’t want to install anything, these online tools work fine for single files or small batches:
For bulk conversions, desktop tools like SysTools or DRS Softech also do the job. It really depends on whether you need a quick one-off conversion or something more regular.
Open the EML file in Outlook or Thunderbird then choose Print then Save as PDF.
if If you need bulk conversion, you can use tools like EML to PDF converters or scripts, but for a few files the print-to-PDF method is quickest and free.
If you have any email client installed that supports EML files or provides a print option, you can perform the conversion manually. However, if you do not have such an email client or if you have a large number of EML files, we recommend using RecoveryTools EML to PDF Converter. This software can easily handle bulk EML files and provides a reliable conversion process while maintaining the original email attributes.
To convert EML files to PDF, open the EML file in an email client like Outlook or Thunderbird. Then use the “Print” option and select “Save as PDF” as the printer. Adjust layout settings if needed, and save the file. Alternatively, use a dedicated Aryson EML converter tool for batch processing, which offer more control over formatting, attachments, and file organization for easier document management and sharing.
Yes, there are a few solutions to convert EML files to PDF.
Manual Solution
Understand the thing: If you have only a few EML files, open each individual file using an email program and then go to the Print and Save as PDF options. The advantage of this method is that it is free but it is very time-consuming for many emails.
Things to consider while converting EML to PDF:
1. Preserve email formatting and metadata.
2. Keep attachments and embedded content intact.
3. Support batch conversion for multiple files.
4. Save time when handling large email collections.
I needed to convert many EML files and I found the WholeClear EML to PDF Converter to be helpful for this purpose. It enabled me to convert many EML files to PDF at once without changing the layout of the emails. This tool was very handy in preventing the boring task of opening and saving individual emails.
My suggestion is to try the demo version first and verify the output with a few sample files before processing the entire collection.
If you only have a few EML files, you can open them in Outlook or Thunderbird and use the Print option to save them as PDF. That works fine for a small number of emails, but it can become tedious when you have hundreds of EML files.
For bulk conversion, I would use a dedicated EML converter. "SysTools EML Converter" is one option that can process multiple EML files together and convert them into PDF while retaining the email content and formatting. It’s more convenient than opening and saving each message individually.
Whichever method you choose, I’d suggest converting a few sample EML files first and checking the PDFs, especially if the emails contain attachments or important formatting.
Yes, converting EML to PDF is pretty straightforward when you only have a few emails, but it becomes a different story when you have a large archive. I’d avoid opening and saving each EML individually because it can take a lot of time and can also make it difficult to keep the original folder organization.
For bulk conversion, I’d suggest trying BitRecover EML Converter. You can add complete folders, including nested folders, and process the EML files together instead of selecting them one by one. It also preserves the email properties, formatting, attachments, and folder hierarchy during conversion, and you can apply filters when you only need a specific set of emails. For a large collection, I’d test the output with a small batch first before converting everything.
If you only have a few EML files to convert, the easiest option is to open them in an email client such as Outlook or Thunderbird and use the Print → Save as PDF option. This is simple and doesn’t require any special conversion software.
If you have a large number of EML files, doing them one by one can become quite time-consuming. In that case, a dedicated EML-to-PDF converter that supports batch processing may be more convenient.
One thing I would recommend is checking how the tool handles attachments, email headers, formatting, and embedded images, especially if the emails are important for records or documentation. Also, if the emails contain sensitive information, I’d avoid uploading them to an unknown online converter and consider an offline solution instead.
For most users, though, Outlook or Thunderbird with the print-to-PDF option is a good place to start.
