Overview
Bonus Tools 2019/2020 is a free collection of useful Maya scripts and plug-ins. After installing Bonus Tools, an additional pull-down menu will be added to the end of the main Maya menu. This menu provides easy access to a variety of tools and utilities for daily use. Maya Bonus Tools has been organized to mimic the layout of the standard Maya menu sets. Each sub-menu contains a number of related tools. Each of these can be torn off and floated just like standard Maya menus.
Note: Due to the close timing of the releases, this update to BonusTools is supported for both Maya 2019 and Maya 2020. This means that new features added in this update will be available in both versions of Maya. However, if you have an older version of BonusTools installed for Maya 2019 you will need to uninstall it in order to use the updated tools from this version.
New Tools in BonusTools 2019/2020
Create -> Locator at Custom Pivot Axis
Modify -> Proportional Placement Tool
Modify -> Stack / Align Objects
Modify -> Offset Transforms
Modify -> Randomize Transforms (Basic)
Display -> Enable Popup Help
Modeling -> Flatten Component (Basic)
Rigging -> Create Joint at Custom Pivot Axis
Rigging -> Create Circle Control
Rigging -> Performance Utilities -> Profile One Frame
Rendering -> Clean up Mental Ray Nodes
Updated Tools in BonusTools 2019/2020
Create -> Mesh Locator
Modify -> Bounding Box Scale
Display -> Poly Volume
Window -> Attribute Collection
Window -> LayoutTools Browser
Window -> Scene Annotation
Modeling -> Curve to Ribbon Mesh
Modeling -> Curve to Tube Mesh
Modeling -> Flatten Component (Advanced)
UV Editing -> Auto Unwrap UVs Tool
UV Editing -> Align UV Shells
Rigging -> Nudge Vertex Weights
Rendering -> Assign Materials for Each Selected
Rendering -> Add Object Transparency Attribute
Maya BonusTools 2020 can be found on the Maya app exchange
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
