In Inventor, you can quickly copy and paste components by clicking a component in the model tree and dragging it into the graphics area. This simple trick can help save you time and streamline your workflow when managing repetitive assembly components!
Steps
- Identify the components/parts you want to copy in the model browser.
- Click and drag the component into the graphic area.
It's that easy and fast—no need for unnecessary clicks.
Note: The copied component/part creates a new instance of the original component.
Check out my video reference below.
This is an ongoing hardtail mountain bike project on the channel. Check it out and learn advanced surface and solid modelling techniques in Autodesk Fusion and Autodesk Inventor, along with a sprinkle of advanced work features.
Autodesk Fusion ⬇️⬇️⬇️
Autodesk Inventor ⬇️⬇️⬇️
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
