Why not build polyline function into feature line
For example, the point of polyline could be click and move to the desired location, However, if I move feature line the same way, elevation of the point will lose.
Another example, I could click the middle of the arch in a polyline and adjust its radius, polyline don not have this function.
and many many other examples:)
1 Comment
AdammReilly
Feature lines are based on polylines, I don't know why you did away with the midpoint grips. Being able to convert a segment to/from line/curve would be so much better than the current methods. Removing a curve is almost impossible, especially if it's the first segment of the feature line.
