Unselectable objects
I would need option that make layer objects not selectable. I often use drawings that has lot objects close to each other and i need to see them on drawing but need to selected for example one object. Think that would be helpful.
3 Comments
Hi Rashasimic,
We use locked layers for this right now.  Would that work for you?
An another alternative is to turn selection cycling on (Ctrl+W). Although Autodesk needs to improve it for AEC objects and allow us to see the name instead of the object type.
doni49
While I think the idea has merit, I would also be concerned about the possibility of having things on these "no-select" layers and then being unable to figure out what layer they're on because they're unselectable.
Maybe some type of "temporarily disable non-selectable settings" command?
