Target parameter highlight
When modify corridor parameter there should be a highlight of target parameter object in the model space. If there are more than 1 target feature line and polyline the name section change to various and now user can no longer find out what had been add or not
2 Comments
joantopo
This is the resason why I only use FL as objects to corridor targets to identify them later from the Prospector from it´s name and highlitght it. However I agree with C3D should highlight  the entity in the drawing once the Corridor target wizard window is open and we select a row.
This would save a lot of time looking for the FL by its name in the Prospector.
TimYarris
Thank you for your idea. In the newer Target Mapping dialog box, targets are highlighted when you select them in the dialog box. Is this what you're requesting, or is it a different dialog box?
Rail Community
