Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Subassembly Composer (window issue fix)
hey !
Then you change window dimension to Subassembly Composer and then back to maximum size you get:
To fix, you need to click on "Create parameter". Why? 🙂 Maybe we can get the fix of that?
2 Comments
cperimanX537E
Another fix. In the "Preview" window switch the "Preview geometries in" from one to the other and it should fix the squishing of the "Input/Output Parameters" window.
Yes it works too! Thank you, but anyways its a bug.
