Subassembly composer (SAC) - Filter geometry labels
It would be helpful, if there was a possibility to filter labels in preview window.
1. I have subassemblies with a lot of points and links, organized into sequences and flowcharts. Sometimes I would like to see only Point/Link/Shape numbers (codes and comments) of geometry, that is inside the current flowchart.
2. Sometimes it would be much cleaner if i could switch the link labels off  to see only points and vice versa.
1 Comment
KMercier_C3D
Similar to this it would be nice to be able to have a drop down list that is populated with all of the Point Codes and Link Codes used and be able to have a Select All, Select None, or check a code or codes individually to highlight all of that code in the Preview.
