A function for label anchor position at the botom plane of Profile/section view would be a great and very helpfull function for labeling of Surface profiles and sections with large amount of grade break Points. As far it's not possible to categorize a grade break Points.
Current way to add the labels is:
1. Add profile Station Elevation labels
2. Add the lables at the required points
3. Drag the labels at Bottom of Plane View
(refer to attached screencast Screen cast, showing the current way)
Suggestion is to create a Station / Offset Elevation Style with anchoring possibility at the Bottom of the View.
