Spirals in axis overwritten
If you have spirals(clothoids) in an axis and want to replace them with other spirals afterwards, you can only do this by deleting the existing spirals as a sub-object and reinserting them with a new criterion.
However, if the project is in an advanced stage and you have, for example, already calculated cross profile lines and cross slopes, then you have to re-construct everything again from the point at which you deleted the sub-object from the axis. This means that the cross profile lines and cross slopes are deleted from the axis by deleting the sub-object from the further stationing.
This behaviour should definitely be changed, so that a combination of e.g. spiral-arc-straight-arc-spiral is simply replaced by a combination of spirals spiral-arc-spiral and does not have to be deleted before.
