Sheet Plan and Plan - Production
Often we need to create sheets, but only in plan, but we lost space because currently only have the options:
Only plant
Plant and Profile
Sections.
Like adding an extra one.
Plant and plant.
To put plant up and down
8 Comments
C3D_TomR
We also need the ability to create and manage two plan or two profile viewports on one sheet.
C3D_TomR
How about viewport options of plan, plan1, plan2, profile, profile1, and profile2?
Just added my vote!  I found a forum post about this back in 2007 where an Autodesk product manager said this was on the list of improvements to be made.  8+ years and nothing yet?  Come on. It cannot be that difficult a programming task.
Here's to hoping it will be in 2017!
Eduardo.Soethe
Thanks this
And I hope so too
Status changed to: Accepted
This idea has been vetted by the community and our product teams, and we’ve added it to our development backlog so that it can be considered for future inclusion into Civil 3D. Please note: we cannot confirm how this idea will be implemented, and/or provide a time frame as to when it may be implemented.
Peter Funk
Sr. Product Manager
Autodesk, Inc.
apweng
In BC we produce plan only sheets and profile only sheets.  It is nearly impossible to create plan only and profile only sheets such that the plan only matchline stations are the same as the profile only matchline stations.  I'm not sure why this needs to be so difficult but I believe it has something to do with the selected profile view style that is used to calculate the layout dimensions.  A workaround is to create plan/profile sheets using a DWT that has coincidental plan and profile viewports.  Once the sheets are created you remove the profile viewports from the plan sheets and the plan viewports from the profile sheets.  This is a reasonable workaround but can be time consuming and tedious for large projects.
If one is creating plan only sheets you would think that profile only sheets would be required and vice versa, and that the match lines for corresponding plan and profile sheets would be at the same station.
Andrew
dsimeone
We've added the ability to create Plan/Plan and Profile/Profile sheets in Civil 3D 2018.
Eduardo.Soethe
@dsimeone and all the Civil 3D team!
This options will helping too much!!
