Setting the Gravity and Pressure Part Catalog via API
Refer to the post here and here.
Now for this feature idea, it's not important at all whether the Part Catalog is set on per drawing ( Pressure Network) or user machine (Gravity Network) basis. That's not my concern.
My concern is that can I do it via API?
Why I need this
I build unit tests for my plugins based on the CADtest idea( described here) , and I would have to load different files and test different operations. But since they require different Part Catalog correctly set to work, so I would need to be able to change Part Catalog as I go from project to project, from test to test.
This is why I need to have an API to do it.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
