Sections visualization priority
When we attach (add) new sources to the SampleLines Group, they are listed alphabetically and by type: surface sections, corridor sections,corridor surface sections and materials.
We can show the same list both in the SectionView Group Properties Dialog Box and "Select Data Sources" dialog box.
The issue is about the overlapping with some surface sections, in particular in daylights with "Top" corridor surface and "Datum" corridor Surface.
If I use the command "SelectSimilar" it doesn´t take into account the style of the selected surface section so I have to select them manually and then apply the "DrawOrder" command.
However, this feature is lost when I remove a source and I add it again later.
A fast way is adding (attach) a particular corridor surface as the last one in the "Select Data Sources" if I want to see it in the top.
However, I hate this and I would like to see a list about a priority visualization.
I think that the SectionView Group Properties Dialog Box  should have a new tab called "priority visualization" with arrow buttons to change the order of  the sources.
This way, sections would be always loaded in the section views in that order.
