Section View sort functionality for additional Sample Lines
The ability to sort an existing Section View Group, after additional Sample lines have been added, due to inevitable design changes.
Currently If adding Sample lines the section views get added to the end but Civil 3d has no means to re-sort the entire Section View Group by stationing.
This is a very common task in our industry and it's very cumbersome to have to delete the Section View Group and create a new one every time a station is added.
There is a workaround to accomplish this, however, a built in solution that sorts existing & newly added Sample Lines / Section Views in proper station order by running "Update Group Layout" or the likes would be a nice feature.
1 Comment
joantopo
I think that the guilty is not adding more sample lines.
I think that the reason is the "group plot style" concept, which is fired at the moment to create several section views.
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/E...
Once the section views are displayed, we cannot change the template or the group plot style settings to modify the current section views.
In that case, we have to repeat the operation "create several section views" again and modify the settings in the steps of the form.
So, if we could modify the template drawing or the Group plot style after drawing the section views and that had an effect on them, it would be nice.
