It would be great if you could label a pipe in cross section so its component is anchored to the pipe lower right quadrant. Then most pipe labels would placed at a good spot and not need dragged. Now when I label the pipes it attaches to the center. I tried to add a line component with an expression for the radius of the pipe but it doesn't work either (I thought that I would attached to text component to the line and not display it.
I think there is a glitch in the labels because then initially are attached to the center of the pipe but when I drag the pipe and reset the label it is attached to the outside of the pipe?
Thank - JL
