Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
SAC: Shape is not closed.
I would like an option to be able to disable this automatic error message.
I hate creating 2 shapes every time with a Decision when my shape can have 3 or 4 links.
If SAC (Civil 3D) can´t find a particular link defined in the shape, then SAC throws this error message: Shape is not closed.  (because it is missed some links).
I would like that SAC ignores the missed links and try to create equally the shape. (and obviously, I could dissable that error message... similar than the intersection points with a checkbox.
4 Comments
KMercier_C3D
This can be avoided if you make a zero length 4th link in the 3 link version and then only needing 1 shape definition.
joantopo
Do you have an example?
My email es [email protected]
Thanks.
joantopo
The issue with a 0 length is than you create Solids (or IFC) from shapes then they are created wrong.. Civil 3D needs a link with non 0 length to create a properly Solid 3D.
TimYarris
Thank you for your idea. We will review this idea as other customers comment and vote on it.
