Show only
Search instead for
When choosing the Properties through the CUI to be displayed for Quick Properties for an object like Polyline, etc.... allow an option for the Area to be displayed in Acres.
Has anybody been able to add acres? I would like to do the same. I'm a surveyor and it would be fantastic to be able to quickly list the acres of a closed polygon. Like what we used to be able to do with "design properties" in LDD ;).
Also, why does Civil 3D provide the Area Property for Feature Lines, if they report 0.00?
While Area is not a Property reported by vlax-dump-object, it does return T for calls to (vlax-property-available-p <FeatureLineObject> 'Area)... So... What gives?
Also, Feature Lines do not support the vla-Explode() Method in LISP, from which we *could* derive a *Polyline to cull for this information as well (and delete once the Area has been extracted).
Especially given the new .NET Feature Line API, the fact that Feature Lines derive from Feature Type, which itself derives from the AcDb.Entity Type (aka inheritance), and AcDb.Entity can be cast as AcDb.Curve, which inherently exposes an Area Property - I'm quite disappointed that Autodesk completely neglected to include Area as a native Property for the Feature Line class.
Revised code - since I am unable to edit my earlier post (how long has this been an issue for Autodesk forums?!) - so that the Reactor excludes Feature Lines from reporting nothing but zeros:
(vl-load-com)
(defun Start:AreaReactor ()
(or *AreaReactor*
(setq *AreaReactor*
(vlr-miscellaneous-reactor
nil
'((:vlr-pickfirstmodified . Callback:AreaReactor))
(prompt "\nArea reactor loaded. \n")
(princ)
(defun Callback:AreaReactor (rea lst / ss area)
(if
(and
(setq ss (cadr (ssgetfirst)))
(< 0 (sslength ss))
(setq ss (vla-get-activeselectionset
(vla-get-activedocument (vlax-get-acad-object))
(progn
(vlax-for x ss
(if (vlax-property-available-p x 'Area)
(setq area (cons (vla-get-area x) area))
(vla-delete ss)
(if (< 0. (setq area (apply '+ area)))
(grtext -1
(strcat "\nTotal area: "
(rtos area 2 2)
" SF | "
(rtos (/ area 9.0) 2 2)
" SY | "
(rtos (/ area 43560.0) 2 2)
" AC "
(grtext -1 "")
(Start:AreaReactor)
