The idea is simple but has a very large applications.
Think you have two channels intersecting you can past both surfaces together with a bottom correction and get a correct complete surface.
Two dikes intersecting, you can past both surfaces together with a Top correction.
You have a area you need to fill to a fix elevation, but the Existing Ground in some places is higher (than the fill elevation). Make a flat surface at that elevation over the interest area and paste it into Existing Ground with a Top correction.
No more "MinimumDistBetweenSurfaces" to insert in drawings 3D polylines to use as hide boundary's.
