Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Offset normal to Surface
This had been discussed so long that the original post aren't even archived.
We need the ability to offset a surface. Landfill caps and certain types of excavation or fill need to be calculated this way. I WAS doing this in AutoCAD back in the 90's using a program called QuickSurf. Fifteen years ago I tried to write a lisp to do this using the NOR function in the Geometry Calculator. But, not being a programmer, I never finished it. So I believe this it doable but I don't know how much work it would take.
Allen
67 Comments
thilina_d
A flat surface can be offset using the Raise/Lower command. However, for surfaces with varying slopes, this approach is incorrect, as the offset should be perpendicular to the respective surface at each point.
AllenJessup
I see this has become popular lately. 😉
joantopo
Trimble Access has 2 parameters to show the elevation from a Surface  (vertical or perpendicular)...
Karsten.Saenger
Autodesk Support
All, this idea is available in the Civil 3D Public Roadmap for voting and adding comments.
Search for "Offset Normal to Surface" here: https://autodeskblog.wpengine.com/aec/roadmap/civil-infrastructure-roadmap/
Karsten.Saenger
Autodesk Support
All, this idea is available for leaving comments and voting on the Public RoadMap for Civil 3D:
https://autodeskblog.wpengine.com/aec/roadmap/civil-infrastructure-roadmap/https://autodeskblog.wpengine.com/aec/roadmap/civil-infrastructure-roadmap/
Search for "Offset Normal to Surface" under "Next".
ntclmain
I've found that:   The tool "C3D CK SurfaceModification 2024" in German country kit provides the offset function
https://download.autodesk.com/akn/2024/civil3d/country-kits/dach/dach_content_c3d_2024.0.1.exe
According to version history, this tool is developed since 2020
For Civil 3D 2025, the "DACH Civil 3D Country Kit 2025.1 for Autodesk Civil 3D" is hosted at https://manage.autodesk.com/products/updates/
AllenJessup
BTW. This feature is on the Next tab of the Civil Infrastructure Roadmap. You can vote for it there also.
