More options for excluding elevations from a surface are needed
Hi!
When we want to exclude elevations greater or smaller than some value, then we get flat areas for the smallest or largest allowed elevations. It would be very good to have an option to exclude faces for these areas at all, that is to get holes in the surface
2 Comments
I like this idea.
If your data is kind of uniform, you can use the exclude triangles edges by maximum length.
Vom2007
Thank you for supporting my suggestion!
However, this is uncommon when we can find the maximum length value that helps remove all edges only in areas with unneeded elevations...
