More flexible layer settings of AVT Report
In Autodesk Vehicle Tracking (AVT), you can edit the appearance of your swept path analysis. You can also use different layering conventions. But when switching these layering conventions off, there is no possibility to change layers (drop down remains grey). AVT Layers.png
Also, it would be preferable to provide the same layer properties/options as the ones available in AutoCAD, including transparency. Now, you can add fills in the Vehicle Body envelopes, but they 'hide' all the info underneath them, making those reports unusable. AVT lacks options to make the solid fill of the body outline envelope transparent. You can only use 'hatchings' to 'simulate' transparency, making the analysis a 'mess' (see attachments of AVT and competition allowing transparency)
Please provide more flexible layering/visualising options.
9 Comments
A possible workaround is to apply transparency to the ATR layer the path is created on
lisa.ballPLCNA
Observer
Please get this sorted Autodesk! It's really essential to have transparency especially when working with Transportation Clients.
Please provide the transparency that we need for tracking.
RDunkley
This is crucial if we are to start using Vehicle Tracking rather than different turning path software.
TimYarris
Thank you for the reminder about this idea. Vehicle Tracking is a tool we're hoping to revisit and this idea is a great candidate.
stensen4Z4UQ
Would be a great to have more freedom to apply transparency to hatch fills in Vehicle Tracking
RDunkley
Hi @TimYarris Can you please advise whether this has been implemented as yet? Regards.
TimYarris
Hi @RDunkley ,
Unfortunately, other things have taken priority over enhancements to Vehicle Tracking. So no, this hasn't been addressed yet.
RDunkley
Hi @TimYarris, Any updates..? Regards.
