The setup:
- We have a pipe network with structures having the style display the structure's boundary both in plan and profile views.
- We have an alignment on top of the pipe network (or running parallel with it).
- We have the pipe network projected on the profile views.
Existing result:
The projection displays the width of the structure.
Expected result:
The projection displays the length of the structure, since we take the alignment (or pipe network) orientation as reference to define the length/width of structure.
Furthermore, rotating the structure does not update the projection's dimensions in the profile view.
The pipes' projection in the profile view does update based on the orientation of the alignment in report with the pipe (ovality of the projection of crossing pipe is dictated by the angle between pipe and alignment, and by the vertical exaggeration).
Can we have the same setting (or coding, not sure what's the correct term) for the structures?
Thank you!
