Make it possible to change the hardcoded code set style label "vertical"
If a subassembly has vertical lines (i.e. the retaining wall), the grade labels show the word "vertical".
Often this information is not needed or simply too long to be displayed.
The idea is to make it possible to change the label string or have the possibility to switch it off.
3 Comments
TimYarris
Status changed to: Under Review
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
joantopo
You can control that using an Expression.
If XLength of the Link is 0 or nearly 0 you will get a  0 value to apply to the height of the text (for that component in the label). You cannot hide directly the label but you can apply height=0 (or 0.0001)
Here an example when an input parameter of width is 0 (it is in Spanish):
https://youtu.be/Z3I1mfU3Asg
TimYarris
Status changed to: Archived
Thank you for sharing that workflow, @joantopo .
