Incorporate an official tool or command to export Civil 3D tables
Kindly requesting to consider adding a tool or command that would allow users to export Civil 3D tables from projects.
As now, there is not such a function and this is a real need from Civil 3D users to submit projects results in XLS, CSV, XLSX, or other formats.
There is a third-party add-in that helps exporting tables, but it is hard to find and download. See the site: Civil3D: Civil Table Export
It should be a built-in functionality as the TABLEEXPORT command incorporated in AutoCAD.
Please, consider incorporating.
7 Comments
TimYarris
Status changed to: Under Review
Thank you for your idea. Are you asking for the in-the-box Civil 3D tables, or AutoCAD tables?
Note that dynamic tables created with Project Explorer can be easily exported to a variety of formats.
MLentzZFHE4
@TimYarris We would like to be able to export Civil3D tables. For example, it would be helpful to be able to export a Pipe Table including size, length and slope to Excel to run analyses.
TimYarris
@MLentzZFHE4 , that example table/report combo can be done in Project Explorer.
I'll keep this idea on the list for core Civil 3D tables.
tcorey
Project Explorer is not 'official' enough?
tcorey
Hi @TimYarris ,
Despite my previous sarcastic comment, I do think this would be very useful, being able to press a button, select a table and specify an output format. It would be the same data format as the table, but as a file. It's easy enough to define a data output format if you understand Project Explorer, but this command would eliminate that often tedious and time-consuming step. Take the onus off the manager and give power to the users. I think the manager will appreciate it as she may have already been through a grueling exercise when creating the table style.
gleonhardt
in the DACH country kit is a functionalitry to export Civil tables to XLS.
Best regards
Gerald
Most challenges, even the "impossible ones" are possible to solve if enough time, money and general resources are put into it. what is not possible though is the generation/creation of more time. in other words if one alternative is less tedious and saves time that alternative will always be the better alternative, provided it comes up with the same result (same quality) as the more tedious one. therefore: an incorporated button for export of civil3dtables seem to be the better solution. (the bare fact that there is a need for this exchange of comments should indicate that todays alternative is to tedious, complex and timeconsuming)
