Improving actions across Civil 3D and AutoCAD products
A problem that is experienced in every modern C3D and AutoCAD version is: inefficient, slow graphics based "features". Allow me to explain some of the issues which I believe have long been sidestepped.
  1.  The Ribbon: The ribbon is slow to react, both when switching between tabs (for the first-time, as if it caches the icons) and again slow with the contextual reactions to commands.
  2. The Ribbon - Layers Tab: The speed at which the layers tab operates is poor - using the pull-down arrow to select a layer, turning layers on or off or simply freezing something is extremely slow when compared against the classic AutoCAD "Layers" toolbar.
  3. A similar experience is had when comparing the speed between the CLASSICXREF to the XREF command and likewise with CLASSICLAYER and LAYER.
  4. The Properties panel: Simply having the properties panel open will cause certain selecting of objects to cause a slowdown in your drawings - this can be said for quite a few different tools as well.
  5. Sheetset Manager: The sheetset manager is a powerful tool, but can also be a very slow tool to use. Let's say a project you're working on has a sheetset and it's located in a different office in your organization - how slow has it been for you to use?
It is my solid belief that a speed improvement release be one of the main focus points for Autodesk to consider - They need to look at the old and the new, consider how tools are used and ask the question of "Why" does something work in a particular fashion and what can be done to improve the speed of the operations.
The main question I have to ask is: Why are so many of the feature rich newer features slower than their classic counterparts?
My two cents on the matter - I would  love to see these features improved.
5 Comments
TerryDotson
I set RIBBONBGLOAD to 0, you're going to take the hit sometime anyway.
What bugs me is on startup (especially the first) it seems like it draws a thousand colored window rectangles trying to get it's window positions established.  Why not save those pixel coordinates on close and if the overall window is the same size on restart, reestablish them.  It's VISUALLY annoying and slow.
rkmcswain
Unfortunately, these speed issues are minor (to Autodesk) and improving them doesn't help sell rent software.
@rkmcswain - if you help vote up this issue and tell your friends then it will become a mainstream issue!
rkmcswain
Despite outward appearances, that's not exactly how it works.
User @sboon said it best "The basic premise which you must keep in mind is that the interests of the shareholders supersede everything else."
tomislav_vargek
what's also bothering, I often use c3d with excel and word, and more often c3d gets minimized and when I restore it, it restores not to full-screen but to some 'size'...
