hide particular labels included in the same label style
Sometimes, I wanted to hide a particular label (aligment label such as the station, geometry,...) or , for example, a section label.
I can´t do this because the label belongs a collection of labels which have the same label style.
My trick is changing the settings of the dragging state tab (from the alignment label style form):
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/E...
I put the leader (Visible=False), and then I drag the particular label to outside the area to plot.
Obviously, this is not a properly solution, so I would like to treat each label in a individual way. (hide/show),etc..  apart of in a group.
In other words, a "Visiblity" property for each label.
2 Comments
troma
You can hold the Ctrl button and click on a label.
Now, just one label is selected, and you can set visibility to false or set it to a different style.
Personally, I like to use a no-plot style rather than visibility-false. This way I have the option to change my mind. I can Ctrl + click on it again and change it back to the default value.
Status changed to: Archived
Due to a low strategic fit, technical feasibility, or the support of your peers, ideas with this status are not being considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
Peter Funk
Sr. Product Manager
Autodesk, Inc.
