HAVING THE PANORAMA PANEL TO SUPPORT GETTING DATA FROM EXCEL TABLE
Many times it is necessary to change the elevations of a large number of points. When editing points in the "PANORAMA" panel, it's possible to change elevation by writing a new elevation, or by "Datum", which will modify the elevation based on a "Delta" value. This works fine if you want to edit a single point or if you want to raise or lower the elevation to all points but with the same value or "Delta".
However, it's not possible to paste elevations from a table. In fact, it's not possible to paste any of the parameters as coordinates: East and North. Many times, we want to update these coordinates or elevations and not all have the same difference. (This happens when working with GPS sessions and adjusting the coordinates and elevations differently for each of the points depending on the number of satellites).
Doing this manually when you have 100 points takes a long time. I know you can export the points, change the new elevations in Excel and re-import them, but it's still a procedure that extends the work for a longer time.
It would be nice if you could "REPLACE" any of the edit columns in the panorama pane, pasting data from Excel and having this panel to ALLOW you to replace the entire column or values ​​selected to get all the points updated. Today, this can only be done for a single piece of data.
The same would apply to editing feature lines.
Regards
