Have takeoff command using selection automatically filter out objects with now pay items
As it works now, Civil 3D will throw an error if your selection set contains the wrong objects. An improvement to the command would automatically filter out the invalid objects (i.e. ones without item codes). This would make the manual selection process faster for the user.
3 Comments
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Okay, I did some more exploration and this seems to be implemented already if you click the selection button:
What I was experiencing was related to pre-selecting objects then running the takeoff command. In this case, you do not get the same result.
So my new feature request is that you can pre-select objects first and then run the takeoff command.
TimYarris
Thank you for clarifying this request, @Coffee_Aided_Design
