Enhancement Request: Option to Suppress “DST File Not Found” Warnings During Batch Publishing (PUBLISH)
Based on customer comments, kindly requesting to enhance the PUBLISH workflow to allow users to suppress or automatically ignore the “Sheet Set Manager – DST File Not Found” warning during batch publishing. Customers clarified that their DST files and DWGs are functioning as intended, and they are not trying to repair or restore Sheet Set associativity. The issue arises specifically when using the PUBLISH command with multiple drawings: each file that has a missing or moved DST reference triggers a blocking warning message, forcing the user to manually dismiss it repeatedly.
The request is to provide an option—either session-based or permanent—to ignore lost DST associativity during publishing so that batch plotting can remain fully automated. The current behavior interrupts productivity and undermines the main advantage of PUBLISH as a batch tool. This enhancement would not modify Sheet Set functionality itself, but would improve workflow efficiency for users who intentionally publish drawings without needing active DST connections.
1 Comment
elucas_KWS
Plz tell me to TURN OFF Feature Line Enhancements made to civil 3d 2026.2!!!!
The why:  add to a featureline a Elevatoin point on the middle of a feature line, than try to mode that point.
I can't move it, can you?
