Enable to label pipe invert elevation at arbitrary location in Civil 3D.
11 Comments
matt_anderson_pe
It shouldn't be linked to just invert but crown - outside edge of pipe...  in profile and or section view.
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
JacobReagan
My company pays a subscription to a 3rd party vendor for this tool, and others, that should be standard out-of-the-box. Thank you @michal.holda. for shedding some light on this.
jwylie2020
Another basic that has been requested before and should of been implemented by now.
MSchille-1994
I've been wanting this for at least 10 years, so add an additional 1000 votes to this post.  The model is there, this should be a no brainer.
NateSarles
QUUX Already has this as an app on the Autodesk app store. It is very limited this way, for the free version, and I feel like it should just be implemented as a vanilla feature!
JayVavra
I would 2nd @matt_anderson_pe 's comment that it shouldn't be limited to flowlines. Using this to show vertical separation distance between to crossing pipes in profiles or cross-sections would be great.
spavlovitsky
Check out the solution for this idea in my LinkedIn post below with a link to github and a short video example
https://www.linkedin.com/feed/update/urn:li:activity:7286689730878971904/
https://github.com/braileee/Civil3DArbitraryCoordinate
jwylie2020
This is great!
Hi @spavlovitsky are there download and install instructions? I see a lot of tiles on github and do not know how to use them.
-John
AmandaJo2323
Is there a way to have the length of the pipe read from outside of manhole to outside of manhole?
MSchille-1994
@AmandaJo2323 this should really be asked in regular forum rather than hijacked from a post in the ideas forum.
Thanks.
Michael
