Would be very beneficial to have a command to transfer the grading from one feature line to another. It would be great to have the option to either move or copy the grading, which would be especially helpful when updating dynamic corridor feature lines after subassembly changes.
The move command would be particularly useful when working with dynamic corridor feature lines that undergo changes, such as when a corridor subassembly is modified. In such instances, being able to move grading objects to a new dynamic corridor feature line without having to recreate the grading would save time and ensure a smoother workflow. Furthermore, it would be great when moving or copying the grading from one feature line to another, the command would ask if you want to keep the criteria, if you say yes, then it would go through the settings of the criteria and the user would accept the current settings or modify it, and if say no, it would open the criteria window with an ok button to continue the command after deciding the criteria settings.
