Coordinate system ETRS89-TM06
I would like that future versions of autodesk civil 3d bring ETRS89-TM06 in the library of autodesk coordinate system, because this is the oficial system coordinate in Portugal.
Thank you.
10 Comments
Pointdump
BMVP,
Until that shining day when it is added to the CS Library, you can put it in yourself.
All the information you need is here:
http://spatialreference.org/ref/epsg/etrs89-portugal-tm06/html/
Dave
bmvp
Hi Dave
I know that but for example map online doesn't work with Etrs89-TM06 added
by users.
Pointdump
BMVP,
I added ETRS89-TM06 just now as a Custom Projection. Bing Live Maps works OK:
Dave
Hello Dave,
For me it does not work, just the north of Portugal appears. you know the reason
I have the same problem!!
Topmig
@Pointdump , i have the same problem as @Anonymous .
I followed this video: https://www.youtube.com/watch?v=575VX2DKKe8 but only appears half of the country.
Can you please explain what i'm doing wrong?
Best Regards.
Pointdump
Sérgio,
What does your "Useful Range: Geographic" show?
Dave
Topmig
Hi Dave,
Thank's for your support.
When i follow the steps of the video, the values are all "0", this is what i get:
The solution is to force those values:
For me your solution worked.
Thank's.
Best Regards,
SR
FrankHuang
Status changed to: Gathering Support
@bmvp Thanks for the idea.
We are working on it now. Have you got some test drawings for us to test the new added coordinate system?
Frank Huang
Autodesk Infrastructure Product Owner
FrankHuang
