Civil 3D for Macbook Pro
Hi. Does anybody know when Civil 3D will release for Macbook? I want to buy a Macbook Pro with M2 Max chip, but I want to use Civil 3D? Is there any performance loss with Macbook? I will use Civil 3D to calculate dredging volume.
Otherwise, which 3rd party program should I use? (Parallels, Bootcamp, etc.)
4 Comments
ChrisRS
This post is better suited to the Civil 3D forum or the core AutoCAD forum.
You can use Report to ask that a moderator move this to a different forum.
(This is posted in the Civil 3D Ideas forum, where new feature suggestions can be made,)
"Anyone that knows can't tell you. Anyone that tells you does not know."
It is my opinion that a proper Mac version is improbable.
Civil 3D runs on top of AutoCAD, and AutoCAD Mac is a subset of AutoCAD. Civil 3D also used part of AutoCAD Architecture and AutoCAD Map 3D, neither of which is available for Mac.
Sounds nice. I hear that Macs are very reliable.
It would be best if you had feedback from someone with real-world experience using at least full windows based AutoCAD on a Mac.
There will almost certainly be some performance loss. The real question is whether or not the resulting performance is acceptable.
I don't have a feeling for how demanding this will be. Feedback from a colleague doing this sort of work in Windows C3D would be invaluable. I would expect to need the same amount of memory or more.
Otherwise, which 3rd party program should I use? (Parallels, Bootcamp, etc.) Sorry, I do not know.
Best of luck,
Chris Stevens
TimYarris
Hi @h.karadere .
As of today we have no plans to support Civil 3D on iOS.
rbernalp
Community Visitor
So, You can't use Civil 3D on Mac.. What are the options?
charlie3H2RM
Apple silicon is running away with performance and reliability. Civil 3D has a pretty poor reputation for stability. Perhaps it’s an opportunity for Autodesk to spend some of their money on improving a key product and offering it to a new user base. Is suspect however we are stuck with x86 for a while, is probably not considered to drive enough profits to be worth it.
They will get caught out later when x86 becomes less common and their competitors are offering ARM solutions.
