If you try to do an alignment with only one arc (center and Radius), and then rotate the circular alignment, the label stations of the alignments appears correctly, but if you save and re-open the drawing file, or you change the Radius, the last location of the label stations will be lost.
So you have to do 2 arcs (throwing 3 points) for a circular alignment.
However, the "automatic roundabout" create a circular alignment with one arc (center and radius) and the trouble is also present.
