batch rename gravity pipes
I would like to have the ability to rename all the gravity pipes in a file base on the start and end structure name. The main reason is using Storm and Sanitary Analysis for pipe sizing, the reports are meaningless with a pipe name pipe (124) vs having an name with like MH-4_to_MH-3 as the name. Doing this manually in SSA is time consuming and also if you do it you would end up with new pipes once the pipe network is migrated back to Civil 3D.
