Idea: create a way to automatically print all pipe profiles and inlet sections after running a hydraflow analysis, instead of doing each section manually, one at a a time.
After running a hydraflow analysis you are provided with a profile view of each pipe run and an inlet view showing the calculated spread for each structure. Currently, if you want to print these for a report or review you must manually print each individual profile, then manually print each inlet section. For large networks printing results might take longer than inputting parameters into the model, a single "print all" or a report that would print all these sections could greatly improve productivity making these diagrams more practical.
There is currently an option to print multiple pipe runs if they connect, however you have to manually set the range of these runs, which involved referring to your plan view and selecting the specific pipe lines, Unless your network is one straight line this can never plot everything at once.
There is currently no way to plot multiple inlet sections.
