Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Automatic update of pressure network naming when the network name changes
Hi
I have recently been involved in modelling existing utilities using C3D 2022. As standard the network would be assigned a name (say A) and when you create a pipe run, the pipes tags/names will have a network name as a prefix. Now the challenge comes when, for one reason or the other, the network name changes (say to B). If I update/edit the network name via pressure network properties, the new name is not automatically pushed through into the pipe tags/names. (pipe names don't update automatically) and this prompts unnecessary remodeling of the network. So does anybody know how go around this issue?
1 Comment
vlaru16
For regular pipe networks, after you've renamed the network you can use the built-in Rename Parts Tool:
Autocad should add this same tool for pressure pipe networks.
