Show only
Search instead for
My Idea is to add a text component to assembly styles. Because the assembly is not intended for printing, the text component can use the default text style, but with the ability to input text codes for assembly name, description, and/or assembly type and counters, etc. It should be a rather simple to implement, but would be a vast improvement over some customized solutions that display the assembly name into a separate mtext object.
