Allow Pipe network Junction Structures to belong to Multiple Networks
Allow the option of designating network junction structures to belong to Multiple Networks.
The thinking is that you make a networks for the existing storm or sanitary works. Then you create additional networks for proposed / future / as-built or phased works. At the common structure between these networks you cannot label (plan or profile) the structure with all the inverts as one or more pipes are not "Connected" to that structure because they belong to a different network.
In addition to labeling, plan/profile part masking should also work when the pipe is attached to a structure outside its network.
Perhaps the structure should have a "home" network so style control is not divided.
3 Comments
KPerison
Or ..... alternatively, at least, allow pipes to connect to structures in other networks.
Charlie.Ogden
New for 2024.1 we have added the ability for a gravity Pipe to connect to a Structure that is in different Pipe Network. The connected Pipes from other Pipe Networks are included on the Structure's Connections tab in Structure Properties.  The Pipe properties and any property set data for the connected Pipes can be included in the Structure labels now even if the Pipe is from another Pipe Network.
KPerison
Woo Hoo!
