Add surface definition information to Project Explorer
We have been playing with the Project Explorer in Civil 3D 2022. Some great features in there, but I think there is an opportunity to provide access to some much-needed surface information.
One of my frustrations working with surfaces is that once several groups of breaklines or contours are added to a surface definition, there is no straightforward way to determine which features are included in a set. For a simple example, maybe I add 4 breaklines to define the bottom of a channel, a second set of breaklines to define the right side of the channel, and a third set to define the left side. It would be great if project explorer included a tab (or a few) under the surfaces category which provide additional information about breaklines, contours, boundaries, or other objects that define that surface. Ideally there would be a way to select/highlight/isolate specific sets of breaklines to help determine which features are included in each set. Right now the feature for selecting a breakline or contour in the Toolspace just selects the surface, and zooming to a breakline set doesn't always make it obvious which objects are part of that set.
I think more granular information about surface definitions is sorely needed, especially when working with surfaces created by others where it may be difficult to determine how a surface was constructed. Seems that Project Explorer would be an ideal place to add some of these features.
2 Comments
TimYarris
Status changed to: Under Review
@Charlie_Magill , that's a great idea -- and would be perfect for Project Explorer. You hit on one of the key use cases for Project Explorer: making it easier for a customer to determine how someone else created an object or model.
patrick_ericson
Agree and that's a great!
If changes is needed to be done to the surface definition, there is no way to know which definition to remove.
/Patrick
