Add Object Data Table Attributes to Property Set Data
I would love to have the ability to create a Property Set Data Table that can point to GIS Object Data that may be in a dwg.
4 Comments
BlackBox_
With the strategic alliance between Autodesk and ESRI announced at AU2017, that just might be on the horizon.
Perhaps an interim step might be to have a custom Command that replicates Object Data as Property Set Data (which already works in Tables)?
I already have a routine that writes Address info to Parcels as UDP; wonder if I can port that to replicate OD as UDP... Hrmm
Cheers
This could be done by the converter of the user's Civil 3D Property Sets <-> Object Data from Map 3D.
For example, in the form of two utilities: PS2OD and OD2PS.
I created the appropriate topic in the Civil 3D Customization Forum: https://forums.autodesk.com/t5/civil-3d-customization/property-sets-lt-gt-object-data-sonverter/td-p....
The converter could give all the full possibilities of working with additional data Map 3D + Civil 3D.
It seems to me that programmers under Civil 3D write such a converter is not very difficult.
Unfortunately, I'm not a programmer.
