Civil 3D Forum
zoom extents...someting off in space
24 REPLIES 24
Message 1 of 25
cadman33619
32004 Views, 24 Replies
hi all
when i zoom extents, my dwg gets very small and hids in a corner...as if there is something else on the page way off in space. i've tried to find it but theres nothing visible. everything is thawed/on and there are no wipeout frames. i tried to Erase All...then deselect my drawing...but still nothing.
what can it be?
24 REPLIES 24
Message 21 of 25
in reply to: cadman33619
I know it's been a few years but try typing in the command 'ucsfollow' and set to '0'.
Message 22 of 25
I had a similar issue. Could not find what was "Lost is Space". The fix that finally worked was to do a Select all (Ctrl A) then deselect the items I wanted to keep. (Shift+Window Select) Whatever was left I deleted with the delete key.
Message 23 of 25
wvhlbly
Thanks for the heads up... good idea..
Message 24 of 25
sgauthier
Came here with this problem and your CTRL-A then deselect what you want method found and deleted the renegade objects.  Thanks
Message 25 of 25
Julian.Feria
check your layers, turn them all on (visibility) and check if there is any extra drawings around the working area.
I had the same issue and as soon as I check all my layers then I found out that some of them the visibility was off and then there were hidden drawings around the work space.
hope it works for you.
cheers,
Julian
Rail Community
