I have 3 files, boundary, survey surface, and GIS surface. The survey was in us survey feet with a North Carolina projection. The other files are international feet, no projection. I changed the survey file to international and no projection. When I xref them together they come in together, it all looks good. However when I data ref the survey surface into the boundary/GIS file the survey surface comes in with a 5000,5000 offset relative to the boundary. The boundary is from a similar survey file where in the zone and units were reset. When I xref the survey surface into the boundary/GIS file it locates properly. I have that feeling I'm missing the obvious again. Can anyone shine a light on this for me?
Many Thanks
Solved by Pointdump. Go to Solution.
Solved by ArchD. Go to Solution.
You may need to set the coordinate system correctly for each drawing using map commands. It's a bit much for me to walk you through, but here is a link that should help you out:
What are INSUNITS, INSUNITSDEFSOURCE and INSUNITSDEFTARGET sys variables se to? Do these setting match what you need?
John Mayo
Those three sysvars are set the same in both files.
The 5000,5000 is throwing me. It’s not the difference of grid and state plan or NAD 27 and 83. It looks more like an arbitrary starting point the surveyor used as is often the case. However the surveyor’s file is state plan. - Still working on it.
Thanks for the assistance.
FM,
Xref'ing won't transform between coordinate systems. Only Attach and Query in the Map Workspace will. Please post your drawings.
Dave
Dave Stoll
Las Vegas, Nevada
Yes the 5000 is not what you'd expect from a coordinate or unit transformation. Aside from Archie's advice on checking INSBASE I would have also checked BASE in the file. Dave hit the nail on the head.
John Mayo
You guys are spooky smart 😉
The INSBASE in the surveyor's dwg is 5000,5000. So that has been my issue all along.
Just for grins and giggles, if you received a file : projection = state plane; units = us survey foot; INSBASE = other than zero and you need to use it in : projection = none; units = international foot; INSBASE = 0,0,0 what would your work flow be?
Thanks all for all the help.
PS: I lied yesterday saying the query transformed all objects. It did not draw the tin nor bring the surface in any way. It also omitted the pipe network.
Any thoughts on why or how to?
Again,
Many Thanks
FM,
"It did not draw the tin nor bring the surface in any way."
The Map side doesn't talk to the Civil side, so you can't use attach/query to transform C3D objects. Just dumb linework.
Dave
Dave Stoll
Las Vegas, Nevada
