Zero suppression within angular dimension styles (degrees minutes seconds)
ManleySurveyTech
ManleySurveyTech
We are having an issue at our office with leading and trailing zero suppression within our angular dimensions. the issue is that we WANT the zeros to display but even with the check boxes unchecked it still suppresses them.  A dimension of 90d00'00" shows as 90d0'0" the only work around we have found is to just override the text and manually add the zeros back in.
Please see attached images for examples.
tcorey
I see the same mis-behavior.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
ManleySurveyTech
I'm hoping this isn't another one of Civil 3d's patented "Known issues"
mcaseyJXMLN
Community Visitor
Community Visitor
I'm having the same issue. No matter what I do, I can't figure out how to get it to include leading zeros. I've tried drawing settings and the dimension settings. Both have zero suppression turned off, but they do not show up.
nkiakas
Hi all
I did not notice it.
If indeed is another bug, then you can use a small .net plugin or Dynamo for C3D graph, to grab all the angular dimensions, search (twice) for the d0' and replace with d00' and '0" to replace with '00" .
Its a temporary solution till the bug will be fixed
Regards
joaquim.moral
Hi @mcaseyJXMLN,
Did the information provided by @nkiakas answer your question?
If so, please use Accept Solution so that others may find this in the future.
If not, let us know so we can keep helping you.
Thank you very much!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager
mcaseyJXMLN
Community Visitor
Community Visitor
I am having this problem again and I am just not sure what a .net plugin or Dynamo for C3D graph is unfortunately.
