Civil 3D Forum
Zero Elevation
9 REPLIES 9
Message 1 of 10
2132 Views, 9 Replies
Zero Elevation
I have to export a civil 3d drawing to 2d autocad. How I can get the points and the linework to be on zero elevation without exploding the points?
Thank you for your help.
9 REPLIES 9
Message 2 of 10
rl_jackson
Set the point style to a use the 0 elevation and flatten the linework
Rick Jackson
Survey CAD Technician VI
Message 3 of 10
in reply to: rl_jackson
I tried to to set point style elevation to 0 under the "settings" - points style - summary - 3d geometry, but it doesn't work, points still have elevation. I also tried "Change" command I didn't succeed as well, something i am doing wrong.
Message 4 of 10
Mike.M.Carlson
@rl_jackson is correct.  I think you just need to edit this from your Point Group Properties to make sure the points already created in the dwg are updating based on this marker style change.  Please see animated .gif below showing this.  White-colored rectangle shape is at 0 elevation.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Message 5 of 10
in reply to: Mike.M.Carlson
I did the same like you showed in your video. Although points in my drawing didn't change the elevation. However when i select one point and moved it its elevation become zero, but i am not supposed to move them.
Message 6 of 10
Here is the drawing.
Message 7 of 10
Mike.M.Carlson
Worked for me?  I had to modify the point marker style on the Display Tab\Model to turn on the layers.  I'm using C3D2018.
Michael M. Carlson
CADD Manager
Message 8 of 10
Once I changed display from "Plan" to "Model" it worked for me too. I wonder if I should keep the display always on "Model" mode?
Message 9 of 10
Mike.M.Carlson
no harm in doing that.  glad it worked for you.
cheers,
Michael M. Carlson
CADD Manager
Message 10 of 10
Thank you!
Rail Community
