XREF's and Raster images cause linework to be unselectable after saving
aalbrech3
aalbrech3
When I add a raster image using map task pane data connect and then XREF another drawing file as well, any linework that exists in the current drawing I add those to becomes unselectable when the drawing is saved. I can work in the drawing fine up until I save. The only way to fix the issue currently is to close the drawing after saving (which usually results in a fatal error) then once I reopen the drawing I can select any thing and work in the drawing fine again until the drawing is saved.
If I just have a raster image and linework and I save, everything continues to work fine.
If I just have an XREF and linework and I save, everything continues to work fine.
The problem seems to happen only after an XREF is also included with a raster image file in the drawing.
hencoop
It seems to me that Map Task Pane Data Connect is the source of problem.  Have you tried another method of attaching the raster image yo your drawing?
Henry C. Francis
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
