Civil 3D Forum
Xref Not Appearing iun Paper Space
11 REPLIES 11
Message 1 of 12
LarryS23
1271 Views, 11 Replies
For some reason, my xref'd drawing is not appearing in a paper space layout. All the layers are turned on and there is no viewport freeze.
Labels (2)
11 REPLIES 11
Message 2 of 12
ChicagoLooper
in reply to: LarryS23
What's in modelspace besides your Xref?
Chicagolooper
Message 3 of 12
LarryS23
in reply to: ChicagoLooper
An aerial image. A surface. Feature lines and polylines. Oh a watershed analysis component to the surface as well
Message 4 of 12
user181
What layer is your xref inserted on?  Is that layer frozen in the viewport?
Message 5 of 12
LarryS23
in reply to: user181
On layer 0. Everything is unfrozen.
Message 6 of 12
Explain why you are putting your xref in paperspace and not in modelsapce.
Chicagolooper
Message 7 of 12
Joe-Bouza
Layers may be frozen in the vport but not globally. Poke open the vport ands roll right in the layer dialog to check vpfreeze
Joe Bouza
Message 8 of 12
ChicagoLooper
The  title of your post is ambiguous. You may know what it means but the wording is alittle confusing to readers of the forum. So your XREF isn't 'appearing' in Paperspace, correct? So where is your XREF located? Did you plop it down in modelspace or paperspace?
Is it possible to upload a screenshot of modelspace? If you XREF is in modelspace, draw an arrow pointing to your XREF as it sits in modelspace then include the arrow in your screenshot. Can you also upload a screenshot from your layout tab with the viewport centered over your target area. The goal of your uploaded images is to see an image that shows where the XREF should be and compare it with an image that shows your XREF missing.
Chicagolooper
Message 9 of 12
LarryS23
Well the xref file contains contours that I want to show. See the attached images.
model spacemodel spacepaper spacepaper space
Message 10 of 12
LarryS23
in reply to: Joe-Bouza
Got it.
Message 11 of 12
LarryS23
Whoops my bad. An easy fix. Sometimes I forget to check that if I do not remember freezing the layers myself. 😐
Message 12 of 12
Joe-Bouza
FYI if you didn't already know. Using the snow flake to freeze object in a view port defaults as vpfreeze. this can be confusing because it wont be frozen in MS
Glad you got it
Joe Bouza
Rail Community
