I seem to be having some issues with AutoCAD Civil 3d 2013... My drawing files are getting larger and larger in size (eg. a 437kb file turned 14mb file when I pasted something in).. I have single drawings with mimimal linework/no blocks/nothing xreffed into the drawing... All that I have done is copied and pasted from another drawing. The items that I copied are created by me in the source drawing...
I am running into a wall with this; there are several other people in my office that has the same issue... I have ran purge all/-Purge/Audit/I have my current graphics driver... I am really not sure on what is going on... this only started when I went to 2013; 2011 and 2012 never had this problem... I have spent hours researching and trying to fix this and have found nothing... I have also turned off my max cache also...
I do have it narrowed down to when I copy and paste something; It usually is just lines and multiline text...
Any help with this would be greatly appreciated!!!
Solved by rkmcswain. Go to Solution.
Please enter AUDIT in autocad.
Fix any errors detected? [Yes/No] <N>: types YES
And once the AUDIT command finished , save the drawing and run ATK-PURGE
Great stuff Ajilal. I have the same error with someone loading my version, I'll be interested to test if the unblocking works, particularly without admin rights. Keep me posted. Dale
FYI: This was released by Autodesk yesterday.
When i run ATK-PURGE-BATCH, files were save to 2013 version. How can we keep the version as it is?
Thanks.
Please find the attached dll's with the option to save the purged drawing in different format
Just an Update.
Now for 2012,2013 and 2014 versions can be download from Autodesk Exchage Apps
