- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Working from home, trying to find the best way to tackle this project (see attached list). Received these drawings from engineer. Drawings ending in C** are separate plan/profile sheets, those beginning with XR*** are Xrefs. You can see in the plan/profile image, under External References that every separate sheet uses the same Xref's. To start my drawing, I open C5, then I use Design Center to add C6 as a new tab/layout, but I get extra layers turned on and some of the text comes in out of scale. It will be time consuming to fix these issues for each drawing. And I haven't even included the survey data yet. Will it be better to keep the drawings separate? If so, how do I incorporate the survey data? With all the years of experience and wisdom on this forum, I know someone has encountered this problem and know the best way to tackle it. Thank you
